My nephew's 1995 -Yamaha RA:cuss: 1100 is running on 2 cylinders. i checked compression in the manual it says 134 PSI. the front one is at 120, the back one is at 118 but the middle one reads ZERO. I tested it twice. so it needs a rebuild. Would just a bad ring cause it to read zero or must it be a huge hole in the piston, loose connecting rod at the crank????
Any other suggestion? :cuss::cuss:
