tresvatos1
I recently tried to winterize my 99 Sea doo Speedster.
I fogged the intakes with Sea Foam, changed the engine oil, and fogged the cylinders.
I hooked up a swimming pool pump to the engine flush port under the hood, and
set the pump into a bucket of antifreeze.
I then cranked the engine and then the pool pump and let them run until the engine was
circulating antifreeze. After that I did the portside engine the same way.
I then removed the battery and sprayed WD-40 all over the electrical connections , and
Amor-all over the seats and rubber lines in the engine compartment.
Would this be a sufficient winterization for this boat?
Also does anyone have a suggestion for a good spark plug, and Gap for this boat?
Thanks for the input
