Wayfaring
My wife used to race a 96 XP back in the day and has been wanting to get back on the water for as long as I've known her. We recently picked up an XP that was completely stock and I've been learning how to work on things from this forum and her old race mechanic (Chris@Watercraft Magic). The first thing I did was to troubleshoot the inoperative VTS. The seller had just replaced the motor and it still wasn't working. These forums pointed me to the rear electrical box and the fuse for the VTS. After opening the rear box, I found about an inch of water in the bottom (along with a submerge blown fuse for the VTS. Replacing the fuse and removing the water fixed the VTS. The next thing to do was to replace all of the gray tempo lines with new fuel lines. The first stainless worm clamps I ordered were M6's and too big. I re-ordered M4's, but they also seemed too big. I read on the forums about using tie wraps and went that route instead, which seemed to work. The battery it came with was dead within a week and wouldn't hold a charge, so that was next to get replaced. Carbs were pulled apart, inspected and cleaned. The fuel filters were almost completely black with a tar like residue, but they cleaned up nice. Low needle set to spec of 1 turn out and high set to 0. I also checked the oil injection pump adjustment and was it slightly off and I adjusted the cable.
First attempts to start it after getting it all back together produced some head scratching. Again, the forums rescued me by pointing me toward the answer. I had two lines reversed on the fuel baffle (which I thought I had avoided by replacing one line at a time, but evidently not).
With everything seemingly working while trailered, it was time to put it in the water and see where we were. We took it down to Body Beach in Lake Havasu last Saturday and my wife had a blast for about 15 minutes before coming in to let me get my first ride on any PWC. It seemed a little sluggish up to 1/4 or 1/3 throttle, but ran great above that. It seemed heavy in turns and at low speed so I brought it in a put it on the trailer. I had intended to tweek the low speed needle a bit, but discovered it had quite a bit of water in the bottom. It ended up being that one of the welch plugs on the exhaust pipe had a hole in it. That ended our day of riding. I had the welch plug repaired and the pipe will be going back on in a day or two.
My wife hates the stock decals and has been using the down time to remove them. Eventually, we'll start adding performance mods, but for now, we'll settle for stock and dependable.
