See if you get 12 volts at the trigger wire of the solenoid with the lanyard in place and pushing the START button. If not, then test the start button for continuity. If it is there, then you still have an issue likely from the water issue. Have to start somewhere to have a KNOWN good or bad. If not, we will just be guessing and that can be difficult and expensive.
