Wont start
Jay138
Ok I'm back for more. My 96 Xp 800 is at it again. I recently changed the fuel lines and cleaned out the gunk from the filters in the carbs. After that it seemed like it was starving for fuel. I just replaced the filters inside of the carbs, and set high speed to 0, and the low to 1.5 as suggested. Now it wont start at all. I believe I'm getting spark, but when I pull the plugs out they seem to be wet, but only with gas. And yes there is oil in the tank. Any suggestions on what to try next??? Thanks for the help.
Jay138
hey...pull plugs and see if theres spark, one at time, with other plug on ground post. Then if ok, clean them up, and set LOW speed adjustment to "1". Its possible, the diaphram in carb/s are bad. If they havn't been rebuild, I'd invest in kit. If so, JPX has sticky/thread on check'n pop-off, with homemade popoff gun. this critical, when rebuild'n them. Dont use any float-arm springs that come with kit, but heres specs/setting for your ski....1996 XP 787 (2)- BN-40I (SB) MAIN-142.5 PILOT-70 1.5n/s 23psi- 43psi LOW- 1 HIGH- 0...:cheers:
The plugs in it only had about 5 min run time on them, but I changed them anyways. Still no go. I only took the carb apart enough to get to the filters, and I was very careful not to damage any of the other gaskets or seals. I don't know jack about carbs and did not want to end up with a hand full of "spare parts" from messin with them. I'm almost ready to take the thing to a shop.
Jay here is a simple solution. The carbs aren't real complicated and you will save in the long run. Here is a $10.95 solution. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
