I’d like to get some advice from everyone here. I have a 1997 Sea-Doo GTX. I rebuilt the dual carburetors using OEM carb kits with new needles and seats. I checked the pop-off pressure, and it’s at 30 psi. There are no leaks. Ever since I rebuilt the carburetors with OEM parts, being advised to never use aftermarket ones, I haven't been able to get the ski to run.
I've replaced all the fuel lines and the fuel filter. I also pulled the pickup manifold out of the fuel tank to ensure all the lines were in the correct order and nothing was plugged, but the engine still doesn’t want to run. I rebuilt the engine last summer, and it ran great until I decided to rebuild the carburetors. Since then, the machine hasn’t run. I’ve taken the carburetters apart four times to ensure nothing was wrong. I even put them in an ultrasound cleaning machine to get rid of all possible debris. Sometimes It will fire up for a minute or two and sometimes it will only run for a couple seconds and then sputter shut off. It was over fueling now I think it’s under fueling. I don’t get it other than there’s something else going on that I’m overlooking. Hi Jets are set right out of the book, at zero turns and low jets are set at one full turn. Any suggestions would be great?
