JACKOMO
I winterized my 05 Sportster 951 as per the manual, however as I poured 100% antifreeze through the water regulator valve I did not see any of the lines fill with antifreeze (Bleed Outlet/Crankcase cooling outlet). I then poured antifreeze through the main engine supply hose and finally saw coolant in the main drain (bottom of cylinder).
It doesnt say anything in that section of the manual to drain the any lines/block first.
I dont understand where all the antifreeze went after I poured it through the water regulator valve as it suggests in the manual.
Any suggestions?
Any suggestions?
