KevinLab010
Hi All,
I am hoping to get some advice on winterizing this boat with someone that has the same or similar. I just picked it up and want to be able to do the winterizing on my own. A couple of questions I have now and see conflicting info on these forums.
1. The antifreeze to use- is there a specific type I should stick to? I will get a hold of a manual to see what it states.
2. The Flush fitting- where is this located? I like the idea of hooking up a hose and pumping in the Antifreeze.
3. The Foggin Oil- does this need to be specific for Seadoos- or will any type work?
4. Lithium Grease- is there a specific type?
5. Coolant Hoses- will the manual instruct on which cooling hoses need to have antifreeze pumped into? My unit has the
closed loop system- so I would think I dont want to mix it up?
ANy suggestions or links are much appreciated.
