I pull off bottom hose on intercooler, hold it down low in bilge and drain the water out, lift it up and give it a drink of RV antifreeze and reinstall,then screw a short hose in the water connection at the back of the boat and start engine, dumping in more antifreeze till I see pink coming out the exhaust then you know it is pickled with antifreeze. The reason I start it up first to blow out excess water then shut off engine and pulling the hose off the intercooler is so you don't dilute the antifreeze. Then do you fogging last.You will see a gear clamp on the bottom hose of the intercooler and a crimped clamp on the top line, just remove the bottom hose.As mentioned before this maybe over kill but sure beats replacing swelled up parts next spring.
