In the next month I'll have to winterize my Sportster, figure I'll change the gear lube in the cones and grease any zerks I see. I'll put stabilizer in the gas, and spray some fogging oil into the cylinders (or should I do it through the top of the air intake port/rubber plug??).
How do I flush the system with RV Antifreeze? Both sides have the hose hook up deal (flush kit?), do I just let RV Antifreeze gravity feed through the system while running each engine? Anything else I need to consider?
Based on what I can tell, it's almost impossible to get to the carbs to drain the gas out of them...
