In all reality ther is anti freeze that is enviromental friendly...ask for it at the auto parts store...
Here is some information on adding the antifreeze. Be sure to use anti freeze made for aluminum block engines. You need to follow the service manual method exactly. The service manual says to pinch hoses, and insert the fluid from the top water line. On some models you needed to pinch 4 hoses. What I did is buy vice-grips with smooth jaws ($5.00 usd each). Fill it with around 2 liters of antifreeze, un pinch one hose, put another 6 oz., wait, then remove the vice-grips. Almost all the fluid will then come out at the bottom. The idea is to mix the antifreeze with whatever water was in the cooling system, so it doesn't freeze.
Karl
Karl
