Now Bro Member Feb 19, 2017 #1 I'm in the process of replacing wear ring and possibly impeller. I'd appreciate any comments on sealing around ride plate to help with cavitation. Also, at what point should I consider replacing impeller? I can already see it's a bit nicked up.
Coastiejoe Moderator Moderator Feb 19, 2017 #2 If your ride late is sucking air. Then yes, it needs sealed. To do the job properly it needs to be removed and resealed.
