brobertov8
yes!! i'm runing with ethnol since january!
i change the fuel injector for more 40% in flow rate.
when engine is hot, Works perfectly, just have a few problem above 7000rpm when ignition timming don't advance!
i built a cold start system with a diesel glow plug, for inject hot ethanol.
when te engine is cold, in the first 30 seconds after started, occours failures in acceleration, but heated, the problem ends.
Here in Brazil, all gasoline have mix on 25% of ethanol, so, nobody engines adjusted for 100% gasoline like a rotax 4tec Works good! very large fuel consumption.
with ethanol, Works better and havea low value than gasoline!
when i advance the ignition timming in 6° and correct the fuel if need, the engine will Works perfectly!
