briancayko
Hey everyone, I have a tandem axle caravan boat trailer for my 2010 challenger. I am replacing some bearings, and have noted that I have the sure lube spindles. One of my grease Zerks always pulls out of the spindle when I try pulling the gun off. It doesn’t appear to be threaded, but rather some type of ribbed pressure fitting. I cannot find a size or part number to direct me to a replacement zerk. I am also having trouble finding new L Rods that work like a basic cotter pin in the end of that spindle. Except that the L rod is apparently designed to not allow any grease leakage out of that hole, in order to allow the rest of the grease to work into the back of the spindle and push the old grease out the front of the hub. Finally, I noticed that my inner seal has some type of spring associated with it. The one that the guy gave me at O’Reillys does not have a spring. Is this going to be a problem, and how should I go about searching for this particular type of seal. Or in other words, what is the name for this type of seal. If anybody has proper names or part numbers for any of these items I would really appreciate the help. Thanks in advance.
