what's the best way to adjust duel carb
seadooer
what's the best way to adjust idle on a dual carb setup? My ski idles too low and will die in the water if i let it go to idle. Are there 2 idle screws (one for each carb) or is there 1 screw for both? If there are 2 do I adjust them one at a time or try and turn them simutaneously? figured I'd ask before i just go try....thanks
Thumb screw....
You have one thumb screw idle stop on the MAG carb.....toward the front. Get a mirror and look under the air box, you should be able to see it.
