BMANN06
Hey all ... have the low oil pressure light coming on ... limp mode.
Started by replacing lower crank case OPS, no change, replaced the one up on top same result. I built a oil pressure gauge, (yes I was lazy in another post .. and I apolologize .. LOL) ... I can see oil pressure building up to around 50 psi on guage, then after about 10 minutes of driving oil pressure drops to about 25 psi and stays there. Can someone help me ... before I park this damn boat on a railway crossing and make an epic youtube video out of it. k sorry for being pissy its just annoying ... little history ...
This is an 04' sportser 4tec, recently rebuilt motor (bout 80% through break in), after the rebuild I took the boat for its maiden breakin .. didn't see this problem come up, but at same time engine didn't see much past 3000rpm. Sold the boat, new owner said breaking it in he could do (which I shouldn't have done .. he doesn't understand "BREAK IN"). Since ... I had to replace the pump and impeller as a result of new owner staring in in a pile of rocks. Since I'm not sure that this problem was there/or not before sale I feel I should fix it.
The fact I see the guage build to around 50 psi tells me the oil pump isn't cooked (sweet) ... what would cause oil pressure to build up to 50 psi and then drop ... regulator??? Any help is super appreciated!!! I'd like to get this guy his boat back by next weekend .. if I don't reply fast its because my wifey has dragged me somewhere ...
As usual THANKS A TON!!!!
