ocod
I got myself into some jet ski's that need motors in both.
Some history,
I got a 96 GTI 3 seater 600 w/trailer. It has the 717 twin carb which if I keep it will be converted to single carb.
The second is a 95 xp also with the 717 for 550.
Here are things I'm weighing.
1. Engine of ski one is pretty bad. It is a SBT rebuild with expired warranty. It would a need new MAG and PTO. That makes it more expensive. It also needs a drive shaft, engine mounts and steering cable.
2. Engine from xp in better shape but still needs top end and bottom end cleaned. It ran before the piston top shattered for a good 20 mins.
3. Crank will probably need rebuilding/replacing on ski one. Not sure if crank needs rebuilding/replacing on number two. Both have metal fragments from piston.
If replaced it will be a hot rod for 600 if it can be rebuilt its ~300. Then there are the remanufactured for ~300.
4. Was thinking options as to who will build it. If all new parts crank/top end and it entails bolting things in, I can do that myself. If it rebuilding and truing crank than experts are needed and it would better to have engine replaced/repaired. I 'm going with FB vs SBT b/c to many horror stories from them. They have the top end kits for $285 but a full build is 950. The difference of 665. I assume the difference are the parts and labor of putting crank and rebuilding bottom and top end together.
If I keep skis and get ~2k invested in engines I'll have two good skis for another 10+ years if I take care of them for just over 3K
or
Sit on the parts and get back as much as the 900 dollars I'm out after selling trailer????
Thoughts??
Some history,
or
Thoughts??
