[MENTION=73220]1of500[/MENTION] , the manual begins the instructions, but mainly tells you how to remove/inspect the front driveshaft after you slide the rear drive shaft out. doesn't go into detail about getting into the shock tower to replace the damper on the back end of the driveshaft. remember, this is the repair manual for a 96 (or 97) they don't have a repair manual for 95, only a parts catalog, and the 95 has a slightly bit different setup..
So, when you say take the two bolts on the shock tower off, which bolts are you referring to? because the BASE has 4 screws into the hull, not 2, and the four bolts are covered partially by the Styrofoam insert, and im doubting seadoo made it so you have to cut away the foam. other option is removing the engine and tank, which I don't want to do.
Or, are you referring to these two bolts? (see second pic) because I took this entire front plate off, (has the 6 screws in it and everything) AND I took these two long screws out. how do I get to the inside of it?
