96spxpos
Well, first thing I learned today was my alarm/sensor is going off at a max temp of 166, so after 2 out of 3 sensors were bad, the 3rd one busted inside the head. Issue resolved. (Admin, feel free to close my other thread)
Second thing I learned:
Looks like I will be pulling the pump off of this ski, I was on my last lap and as I was about to shut the ski off while idling in, I heard a bit of rattle, but chalked it up to a combo of the seadoo rattle and a little sea doo container I had put inside the hull with my temp gun in it rattling. I took the container out, ski started again with an awful rattle. I pulled it out immediately, went to start it and it did it again, only louder. I got it home, checked the pump, all clear, impeller clear, intake grate clear, the carrier setup looks straight, no torquing, no rips in boot, but I only wanted to run it one more time quickly for you guys to see. Trust me, I didn't want to run it that long, my hand slipped when I went to shut it off, so I just grabbed the lanyard. Hard to take a video and be up front to shut off at same time.
So, knowing that this ski (95 HX) has this secondary drive shaft setup kinda like the newer XP's, I'm scared to even tear into this thing. If impeller looks good, motor mounts didn't bust/etc.. What would you guys assume this to be? I'm at the point of just taking it in somewhere. Any ideas?
https://youtu.be/k-4iL4spjQQ
