Update...
looks like the cavitation should be fixed with the driveline rebuild kit and threw on some new Solas impellers. I didn't take it off the trailer but it was sitting in the water and wanted to move the boat as opposed to originally not doing anything.
Now the other issue I can't seem to figure out why it isn't running consistently and smoothly as to this is what I have:
1. Correct carbs that are newly rebuilt
2. I'm not sure what direction the fuel is going so the recharge jets in the small dia. fuel lines are going the correct direction.
3. Fuel is at least 6 months old or as far as I know could be 1 year old and probably no stabilizer was ever used.
4. New sending unit
5. No more Tempo lines and all new fuel and water lines/hoses
6. Choke seemed to work fine as I stated it in the water with air temps at 55 deg.
7. Spark Plugs look normal
8. Oil tank is full with fresh oil
9. Lo fuel adjuster is at 0(no turns out) and Hi adjuster is at 1.5 turns out.
10. For some reason all of sudden there isn't any fuel squirting in the carb from the squirter thingy like the port side when turning the throttle body by hand. This would obviously stop that motor from running which was not doing so well while testing it out in the water. Maybe some blockage or an air leak in that vacuum/pump thingy attached to the carb.
This is what I plan to do this week:
1. Replace the full tank of fuel with new with some type of siphon or pump and do something with a whole lot of fuel, probably distribute most of it between our car and truck as I'm sure they can handle it better than the boat if the octane is low or maybe has some water in it
2. Adjust the Hi and Lo fuel adjusters to Hi being at 0 and the Lo to 1.5 turns out, as I guess I had them backwards(dyslexic of me)
3. Swap the recharge jets 180 deg.
4. Figure out why the heck there isn't any fuel squirting in the carb from the squirter thingy like the port side when turning the throttle body by hand.
Or just drop it off and bend over and take it in the A** because my diagnostic skills are terrible and I'm really frustrated with this :-(
