I just bought a 98 sportster 1800 a few weeks ago and posted up it wasn't running right and had cavitation. All the parts came in and I'm conifers to when I put the Solas impellers on along with new seals the cavitation will be gone.
The problem I have is before my starboard motor was t running right so after tearing both carbs off and replacing small rule lines on the carbs, rebuilding them, replacing a few water hoses, and welding up the exhaust, the starboard side runs better but won't stay running like the portside. I don't know if the port side is running correctly but it does run and it reves up and idles. There must be some re limited when in the neutral position because it won't rev up past 5k until I put it in F or R.
The starboard side will run if I play with the choke, which tells me it needs more fuel or less air for the amount of fuel it getting at idle who which on my diet bikes it means the pilot is screwed up. There is only one thing I didn't pull out is I think was the main jet OT at least the low/high adjuster thingy. The strange thing is it will idle for a few seconds and die or I can get it to rev up to 7-8k no problem then it starts to die unless I pull the choke.
