Weeds
Funonwater
What is the easiest way to get weeds out of the impeller and intake?
Do get them very often but when I do they are a challange to get out.
Thanks
There is a special section in your Owner's Manual for your Sea-Doo that explains how to do this.
FIRST: While in the water, turn OFF your motor. Then, press the START/STOP button to turn over the engine and impeller but DO NOT start the engine. Do this a few times to "spit" the weeds out of the intake and jets. Turn on the Sea-Doo and see if it is operating properly. If that doesn't work...
SECOND: I don't know about your RXP 215, but my RXT 255 iS has the iBR (brake/reverse) lever on the left hand side. My manual says to alternate between forward and reverse several times to clear out any weeds/debris out of the intake. If that doesn't work...
THIRD: Ride your Sea-Doo onto a beach and put a large piece of cardboard under/next to it to prevent scratches. Roll it over onto its side and carefully remove all weeds/debris from the intake grate. If that doesn't work...
FINALLY: If none of the above mentioned techniques work, bring it in to an authorized Sea-Doo dealer to have the intake and impeller professionally cleaned and inspected.
I hope that helps. These are the things my manual said to do in the "Special Instructions" section. Good luck! :)
