Hello,
I would like to know the disadvantages with the stainless steel wear ring. In my opinion if the pump is going to suck FOD (foreign object debris) the impeller is going to get the hit on the leading and trailing edges. Why sacrifice a soft outer diameter shroud, basically that is what the wear ring is, made to maintain tip clearance of the impeller.
Thanks,
Henry
Thanks,
Henry
