Either a stubby wrench, or a "Crow's Foot" socket. OR... heat up an old open end wrench, and bend it 90 degrees. (like an old distributor wrench)
Not an O2 socket... a crows foot. Like this...
But maybe I'm not understanding the question completely.
Thanks for the advice Dr Honda. I bit the bullet and ordered the Merc impeller socket today. I will get the ring off after the impeller is out
and take a good look at the shaft. Would you have input on what to do with the stator?
Thanks for all the great advice guys, and the detailed description above.
I will use the wood puller idea, I think I have a few 2x6s laying around.. based on your diagram, Im assuming you just used a 1-2 inch bore bit for the middle of the board to allow the shaft to pass thru? The bolts from my steering wheel puller are very close if not the same 3/8 bolts that hold the wear ring in. Guess Ill start on that stator while I wait for the socket.
More problems...
The manual says the nut is a "standard right hand thread" unless Im somehow misinterpreting that statement, it means the nut comes off in reverse of a normal "standard left hand thread". So, when I would be tightening a normal nut, Id be loosening this one right? Any suggestions would be appreciated.
Looks very good, Eddie. What was your top speed before this work?
Looks great Eddie. Im still working on mine, going the JB weld route too. Recd an e mail that my impeller is on its way back from Impros, was 125 plus the shipping. I didnt talk to them except before shipping it out, so hopefully they did as nice a job on mine as they did on yours..
Yep... looks good.
I'd like to hear about the CS probs. There has been a few this summer.
