I came up with a novel fix for the pitting around where the o-rings sit with the top hat. I used a marine epoxy filled in that section of the drive shaft. I then sanded that section to bare metal. The pits near the o-rings are partially filled. So it's not great and with grease it should fill keep the water out and reduce more corrosion.
Speaking of corrosion, I know why the 30 amp and accessory fuse kept blowing. The weedless system motor is completely shot.
So there goes my drive shaft savings...at least I can get the boat in the water and wait on this part.
ohhh, do you have any of your research for that motor? I will start researching in that direction when I get home. Great Idea!Completely normal that motor in that condition - rust and dead -.
I had an 1995 XP and it was exactly like that. At least here in these lands, I found the exact same motor from "car electric power windows" for a good price, and works!.
There was a thump and everything went whacky. I am taking it out of the water tomorrow and will take a movie of it running. It maybe an alignment issues.Snap a pic of the shaft and all in the boat. It might be a easy fix. It is odd it only leaks when running- not enough pressure on the carbon seal or maybe your pump is out of alignment??
forgot to install the black rubber bumper at the end of the driveshaft which gave too much play and not enough pressure against the black boot
