Some good basic information here. I'll explain it in further detail.
When the piston comes down and the exhaust port opens, the expanding exhaust gases escape as well as a sonic wave. As the piston goes down further, the transfer ports open and allow the fresh air/fuel charge to enter the cylinder. The piston continues down through bottom dead center and then as it goes up, it pushes some of the air/fuel charge out the exhaust port. The sonic wave travels to the end of the pipe (the convergent cone) then bounces back towards the cylinder and if it's timed right, the sonic wave pushes the escaping air/fuel charge back into the cylinder just before the rising piston closes the exhaust port. A longer pipe works better at lower RPM and will cause the sonic wave to take longer to return as it allows the piston to come back up. Conversely, at high RPM, a shorter pipe is more desirable as it reduces the time it takes the sonic wave to return to the cylinder. Also, the speed of the sonic wave depends greatly on the exhaust temperature. The higher the temperature, the faster it goes.
So, if you have a pipe that is tuned for high RPM (short pipe) you will have good top end but a mediocre low end acceleration. If you inject water into the exhaust stream at lower RPM, it cools the exhaust gases and slows down the sonic wave causing it to act like a long pipe. As the engine speeds up, the water injection shuts off allowing exhaust temperature to increase and the sonic wave to speed up. This gives you the best of both worlds.
RAVE valves also change the timing of the sonic wave. As RPM increases, the RAVE valves move up and the exhaust ports open sooner to release the sonic wave quicker.
Click the link. :coolgleam:
http://upload.wikimedia.org/wikipedia/commons/5/52/Arbeitsweise_Zweitakt.gif
Chester
