lucseadoo
I have a 2005 4tec Sportster. The boat recently was in repair for the engine water pump (coolant). Since return from repair when running the boat in the water the engine get water in it. Thus, the boat won't run. I pull the plugs turn engine over to remove water keep filling with WD-40 until the engine will run. The boat had never been towed and never flushed unless engine is running. I know water cools the exhaust but why would it get into the engine compartment? I took it back to the shop and the mechanic assured me he test rode the boat and no issues with water in engine. He did change the oil 4x and the plugs. I put the boat back in the water. Cranked it at the dock -ran for about 30 secs. Parked the truck and when I tried to start it would not. Checked again and water in engine. Now back to the vicious cycle of removing plugs/changing oil and lots of WD-40. The mechanics have no clue. Anyone have similar problem with a solution?
Head gasket? Plugged exahust vent line?
Thanks!
Thanks!
