Lwells587
Yep, water in the cylinders always makes it's way into the crankcase oil. And most cases of water in the cylinder I see are a result of a cracked exhaust manifold from winter freezing / poor winterization technique, Sometimes a cracked head or head gasket are responsible, or maybe the boat sank (can even sink on the trailer if drain plug isn't removed or gets clogged.
In salt, I give most exhaust manifolds a 5yr average lifetime.
I’ve owned the boat for 4 years now bought it second hand only now has 84 hrs on it and really haven’t done anything to it except and couple oil changes this winter may have to crack open the maintenance manual and start replacing some filters and other things. Will differently be giving the exhaust manifold a look over when I get back
