Water cooling ?
GangreneRabbit
I have all ways called it a pee hole :rofl:. The water exit port after it circulates through the motor. Where is it on the 1997 GTI? There looks to be one on at the tow hook for tubes and one on the right side. I want to make sure its cooling properly .
Water exit
The one by the tow hook is the water indicator. The one at the front right side of the ski is the battery vent.
DAWG
Should it be a fast stream? I see now that its T off and the bigger hose (3/8) is going strate into the exhaust if so what should I look for and can it be tested out of water? There is a slow stream comming out there (my wife is now telling me this) I should have ask her first!!!!!!!!!!!!!!!!!!!
Thanks G-Rabbit
Water
It's not unusual from the steam of water to seem weak when running ski out of the water. The stream of water will usually be alot stronger when the ski is being run in the water.
DAWG
