well, it might be a little more complex than that, but lets see.
The VTS unit has a series of magnetic reed switches in it, that do two things. They give the position of the trim unit for the gauge, & at the limit of travel (up & down) they release the relay for that direction so the motor doesn't over run & mechanically bind. Is your trim currently all the way up, or down? If so, replace the fuse (if its blown) & see if it will go the opposite direction. When the trim gets all the way to the limit, the motor should shut off & when it does, there should be no relay click for that direction if you try to make it go further. however, if you move it in the opposite direction you should get a click & the motor runs until it reaches the other limit switch. IF you have no gauge movement, there is a chance that your sliding block needs a new magnet. The early style magnets sometimes rust away, the later designs had an epoxy coating to help seal them up. check these things out when you get a chance & let us know.
