Well my knee is really screwed up. Sprain of MCL, complex tears of lateral meniscus, and 1/4” loose body (bone or cartilage), shown in mri. Waiting to get into orthopedic surgeon. My leg limits what I can do but I can still do simple things that don’t involve bending the knee.
In the meantime, i got up to the lake and installed the correct injectors. So new plugs, new coils and new injectors.
Starts fine and idles fine, again remember I have no water and can’t get it into the water so running time is in seconds.
Once i use the throttle lever, the engine revs up but I can’t control the rpm. If i let go of the lever, it still keeps revving around 4000 rpm and doesn’t return to idle. It will rev up to higher rpm and drop to a lower rpm but never even close to the correct idle rpm
If i shut it off and restart, it starts and runs at idle speed.
Throttle acceleration sensor or throttle position sensor issues? Seems strange, even when i had poor acceleration and low top speed, the throttle lever response was normal, release the throttle and it returned to idle. Not anymore, seems like I created another issue. Is there anything that I might have disturbed while removing the throttle rail and removing the fuel injectors?
Any ideas?
Larry
