I live in South Florida and took my boat out for it first run since purchasing in March. Ocean water temperature was around 80 Deg. When running my Bilge pump I noticed the water coming out was very hot (Almost burning my hand)
Could this hot water be caused by the cooling plate which is located close to the bilge pump ?
So far I have checked the following.
I ran the engine on land for about 10 min and did not see any water leaking from the hoses.
Checked the temperature of the engine with a laser thermometer and it had a constant temperature and did not continue to rise over 155 deg (dashboard has never indicated an over heat problem)
When I purchased the boat I noticed the water reservoir was empty and had to add about 1/4 gallon of water.
I did not think this was an issue since most cars I own the tank is empty ( figure flows out when gets hot.)
Don't think the little bit flowing out can cause the hot water coming out of my bilge pump.
( After my first run it was empty again)
I have always owned an outboard engine and this is the first inboard I own. On my previous boats I never noticed the hot water coming out of my bilge pump. Please provide any feed back.
I want to make I fix any issues before getting broken down in the bay.
Thanks..
Thanks..
