Got this ski all sorted out and running. Took it out for its maiden voyage. Ran great until I noticed how low it was sitting in the water. Loaded on the trailer and hull was half full of water. I’ve checked all of my water lines and all are secure. The jet pump came with a spacer. When I re-installed the pump I put orings on each side of the spacer but I think my problem is not getting a good seal. I even used some through hull sealant. The more I ran the ski the more and faster the hull filled with water. I believe the bailers are pumping water into my ski. I’ll add some pics of the spacer as I would like to use the spacer.
