Finally got it all up and running. Took it for a water test, idled out of wake about 45seconds....Ran it for about 45 seconds....saw the warning light, let off throttle, heard the horn, and engine stalled as I let off throttle. No starting again.
Try to start the engine with plugs in, and it will turn over maybe 1 or 2 cylinders, then stop (can hear bendix freespinning). Take all the plugs out and engine turns over strong.
Put a compression tester on it, and I hit 150 right off the bat on cylinders, except number 2 was a bit lower at 100/125 (forget). I could keep cranking it over a little and got at least 1 and 3 to 180ish. I had trouble getting the starter to continously engage on 2 cylinder with comp test in.
After I took a compression on each cylinder I went to double check. My numbers were vastly different. Sometimes I would just get like 50-75 and that was all. Sometimes I would get 150, then the next one 75.
Pretty soon I noticed that anytime I did a cylinder, I would get like 150, then 75, then 50, then as low as 20. With the starter engaging.
I was not cranking on them long, maybe 2-3 seconds each time. I've done plenty of compression test. I also check battery voltage and it was 12.8-13.1 (had a charger on it) at the starter relay going to starter. I felt the starter and it was NOT hot. It has a brand new battery and even brand new battery cables.
Any ideas?
Any ideas?
