Utopia double fuse block problem
GCrane
I had a problem with loss of power to accessories. It wasn't fuses or ground that I could tell. Another forum member suggested it was likely just the left block of fuses (as you look aft) and it may have to do with the ignition. On his advice I was able to switch things around and get the essentials working.
Does anyone know if is a problem with the ignition or the fuse block itself? If it is the ignition will replacing it correct it?
Check the "batt fuse"
I have a similar problem with my Utopia which lost power to part of the fuse block when my trim tabs overloaded it. There are 4 additional fuses located in the rear of the boat (I have found them on the wiring diagram but haven't had a chance to locate them on my boat) in a box probably near the battery switch.
I am sure you will find one of them bad. I will let you know what I find on mine.
