ID62
Hello Seadoo buddies,
After a couple adjustments I was the third time on the water with my new (used year 2006 w. Rotax 155hp) Utopia 205. I guess she was sitting a couple months in the marina and it might be that the gas was also old. So far I didn’t drain the gas I only filled it up with new gas. Once the engines are cold both engines fire up right away. But if you reached the operation temperature the starboard engine is hard to start and I have to crank it 2 to 3 times until it starts. Surprisingly sometimes it fires up right away even it has the operation temperature. Since the injected gas quantity is controlled by the ECU I guess one of the 4 sensors which are used for this gas control have a failure. Beside the hard start up sometimes the engine runs great without any problems. So I thought it’s the manifold air temperature sensor which gives the wrong temperature. But when I measure the resistance it is within the limit. It could be also the manifold air pressure sensor but on the other hand….. engine runs great. The shop manual says it can be also the idle bypass valve, but once the engine is running it idles also great.
Your input is much appreciated to figure out the reason.
Then for those who are missing the table, I found one in a German boat shop which is fitting 100% without rework. Price is roughly 110 Euro for the table and the mount below the table. The original post fits perfect.
Thanks and greetings from Germany
Ingo
Ingo
