Palm Bay Chuck
So my local boat shop is doing the CDI Switch Box replacement for me, but they said that doing the stator oil change is going to be difficult and time consuming. They said that the bolts that hold the unit in place are seized up. They suggest that under normal circumstances, the procedure takes little more than an hour, but when these bolts are seized, which is common, then it takes up to a day because they have to drop the whole unit, drill out the effected bolts, tap new bolts holes and then put everything back in place.
So, I'm going to skip the oil change for right now and research ways to unsieze those bolts! Does anyone have any suggestions?
Thanks everyone.
Thanks everyone.
