I have recently got a 2002 GTX DI and done a lot of work overhauling it. I took it out on the water last weekend and noticed that It would run great up until 75% throttle but if you go past that it will bog down. But it will do this no matter if its from a standing start or 5000 RPM (which is the max I can get out of it while in the water). As soon as you got past 75% its coughs and splutters.
I have checked the fuel pressure when I got home while the ski is on the trailer. It is around 107 PSI when cranking and runs great! but when I get to around 6000RPM the pressure starts to fluctuate. I already put a brand new Quantum fuel pump HFP-342DI in along with new regulators and injectors except for direct air injectors. I have heard about the HFP-501DI pump if anyone knows the difference? or any other suggestions for this issue
