treetopflyer737
First time posting on here, Hello everyone! :biggrinjester: I'm in the middle of a bottom up rebuild on (2) 787 Rotax motors. I have two questions for some of the more experienced motor builders on here.
1.) Honing. I've been doing my research on two stroke cylinder honing and it seems that there are three methods people use on two stroke cylinders (a flex-hone ball hone, a 3 finger hone, or a nylon brush style hone) with the most popular style being the brush hone (http://www.amazon.com/Wiseco-Nylon-Flexhone-Brush-45-57mm/dp/B0045LB5WC) due to the fact you will not damage the multiple ports found throughout the two stroke cylinder. What are you opinions on these three (ball hone, finger hone, brush hone) on a rotax cylinder? I do not have a large drill press and 3 of my 4 cylinders are going to need deglazing.
2.) Oversize Piston Question. So one of my cylinders has a a nail grabbing scratch on it along with a dry seize area and will most likely need to be bored to remove these imperfections. On a twin piston 787 motor, can you oversize 1 of 2 cylinders to .5mm or will it throw the motor balance off??!! Would my best bet be to have both cylinders bored to .5mm over instead of just doing the one that needs it?
Any help would be appreciated, thank you!
