RPM at WOT is still 8000 or 7980, still 55mph top speed of course as the impeller and rpm is the same. But you can feel it has more power. Cavitates the impellers much more now going idle to WOT than before. If you can only pull 7000 rpm with the impellers you installed, I believe that means you need more hp to spin them to the full rpm. Where did you order your impellers from?
