sandals99
Hi Guys,
not sure if my two pumps are working. Noticed that the ballast was full of water as the manual valve was in the open position when we were on the lake so it must of filled up the bag. I noticed when I got home, put the key to the on position and flipped the ballast switch to the empty position but nothing happened, couldn't hear it all, even flipped the switch to the fill position but couldn't hear the pump turn. I ended up opening the ballast bag and let the water drain out slowly. I noticed that on my circuit breaker under the steering wheel there isn't a breaker for the ballast, so I need to locate the fuses.
Anyone have any experience with this?
thanks!
thanks!
