Trouble starting 97 GSX
1roofman
When starting sometime key works sometimes not. have new key programed at dealer. I noticed if I hit the SET button next to the mode button the engine dies and it takes a while to start again. Also after the set button kills engine I remove and replace key,hit starter button and just get a beep it won't start. Any body know whats causing this?
Try Advanced Self-Diagnostic Mode
It needs to be enabled manually. Proceed as follows:
1. Remove safety lanyard cap from watercraft switch.
2. Press 5 times on the watercraft start/stop button.
NOTE: 1 short beep and 1 long beep must be heard. They validate beginning of diagnostic mode.
3. Install safety lanyard on watercraft switch.
4. Press the watercraft start/stop button again
NOTE: If everything is correct, engine will start.
Let us know what you get, 1 long and 1 short beeps, 2 short beeps, 2 long beeps, or 3 short beeps.
