Hi all,
My 1997 GTX suddenly stopped running properly; the engine was fine but it wouldn't accelerate properly at all so I know something was up in the drive train. So pulled off the reverse gate and found that the impeller had somehow managed to hook the wear ring and mangle it and get all tangled up with bits of it. So, clearly time for a new wear ring and probably a realignment of the engine. Removing the jet pump seemed fairly straight forward but proved to be otherwise. Once removing all the required bolts I pulled on the pump assemble expecting it to pull off like all the videos I watched but no, it would not come off. The pump was not stuck on the hull it was the impeller shaft preventing it from coming off. I was simply stretching the rubber boot on the PTO. I could not figure out how to separate the pump from the shaft. Eventually I gave up and removed the rubber boot on the PTO, removed the C clip under the carbon seal and then the pump came right out with the impeller shaft still attached. Is that what is supposed to happen? Did I miss a step somewhere? I can replace the wear ring with the impeller still in place and then slide the whole works back in and bolt it up but I can't figure out why the jet pump does not come off the impeller shaft like all the videos I watched.
