A little research on batteries...
When I was about 14, I was taught by my mentor (my uncle) in engine rebuilding, that you don’t leave a battery on cement. That it would cause it to go dead. I have lived by that rule ever since. Well, it was pointed out by a fellow forum member, who is experienced in batteries, it was a myth. After doing a little research, I found truth to what he says and to what I said. As quoted below, it states that when batteries were cased in hard rubber many years ago, they would lose their charge if left on the cement. Well, that would be when I was about 14. Today, the battery casings are made with different materials, so it seems that rule should now be thrown out the window!
Credit to
www.TripleCrowngolfcarts.com for the use of their website to get this information and I hope it gives some insight to your battery questions. I found it to be an interesting read.
How does temperature affect the performance of my batteries.
At higher temperatures (above 77 degrees F) battery capacity generally increases, usually at the cost of battery life. Higher temperatures also increase the self-discharge characteristic. Colder temperatures (below 77 degrees F) will lower battery capacity and prolong battery life. Cooler temperatures will slow self-discharge. Therefore, operating batteries at temperatures at or slightly below 77 degrees F will optimize both performance and life.
Do batteries self-discharge when not in use?
All batteries, regardless of their chemistry, self-discharge. The rate of self-discharge depends on the type of battery, the age of the battery, and the storage temperature the batteries are exposed to. As an estimate, Trojan batteries self-discharge approximately 4% per week at 80 degrees F.
Does my deep cycle battery develop a memory?
Lead acid batteries do not develop any type of memory. This means that you do not have to deep discharge or completely discharge a battery before recharging it. For optimum life and performance, we generally recommend a discharge of 20 to 50% of the battery’s rated capacity even though the battery is capable of being cycled to 80%.
Overcharging: Continuous charging causes accelerated corrosion of the positive plates, excessive water consumption, and in some cases, damaging temperatures within a lead acid battery. Deep cycle batteries should be charged after each discharge of more than 50% of the batteries rated capacity, and/or after prolonged storage of 30 days or more.
What are some common myths associated with batteries?
• Half of a non-buffered aspirin in each cell and then a fast charge breaks up sulfation and extends battery life- Aspirin forms ascetic acid which attacks the positive grid and active material.
• Storing a battery on concrete will discharge it quicker- Long ago, when battery cases were made out of natural rubber, this was true. Now, however, battery cases are made of polypropylene or other modern materials that allow a battery to be stored anywhere. A battery’s rate of discharge is affected by its construction, its age, and the ambient temperature. The main issue with storing on concrete is that if the battery leaks, the concrete will be damaged.
