So I’m really impressed how easy those Allen bolts removed. I’ve recently discovered how effective thread lock is at sealing out water. Normally I put grease on wet bolt threads, but I’ll be putting these back in using thread lock.
I dropped the leaf spring shackles to reach the brake mounting bolts.
I also learned the original UFP DB35 brake calipers were zinc plated steel and if you replace it with the aluminum caliper, it makes contact with the galvanized wheel. I’ll hopefully have the zinc calipers this week to confirm they will fit.
UFP 10” brake rotors with steel zinc calipers:
K71-773-01 caliper ass’y left
K71-773-02 caliper ass’y right
