I picked up a 2001 GTI: I believe a 717 engine, sticker says 718cc engine? end of Nov.2015
Let me mention that the engine is grey, the exhaust manifold is white and the exhaust pipe is black.
I have gone through it since then doing the "many things" suggested in the threads posted by the great experienced people in this forum.
THINGS I HAVE DONE:
New Battery, grey fuel lines out, fuel selector cleaned out, fuel filter good, new plug wires and plugs, drained gas tank, oil injector gone went with block off plate (ethanol free gas from now on) mix 40:1 right now still in first tank of gas since block off installed, carb gone through/rebuild, new Needle n Seat, new jets both main and pilot, cleaned out bilge boxes, put in new bilge tubing, found a hood with working gauges MPH and fuel oil indicator.
ALL OF MY TESTING AND TUNING HAVE BEEN DONE IN THE LAKE UNDER LOAD
To my knowledge from manuals I have found online 717 engine with a Mikuni BN40I-38-48 have not verified that?
WHERE IT IS AT RIGHT NOW:
Starts right up no touch throttle or choke revs to steady idle cruises nice and smooth in no wake speeds
I have returned carb to OEM specs by going with a 75 Pilot 167.5 Main 2.0 N/S pop off is consistent 22psi tested 4x LOW speed out right at 1 3/4 HIGH speed out just a bit past 1. I have great low to mid range transition gets up on plane then no faster then 25mph, this is all with the black air box off,
HERE IS THE KICKER: Question ????
With the seat off and sitting on the right side and right hand on throttle I can gas it from idle (no hesitation) to a steady 25mph WOT, then I reach down and "cup" the airfilter/flame arrester with my left hand, this thing gets up like a rocket to about 52mph me hanging on with one hand,,,lol. Is it time to put the "air box" back on ?
I have NOT done anything to the accl pump assuming it is fine or that is the cause of my issue.
Has anyone experienced this, can anyone tell me what I have missed, can anyone tell me what to do to make it right.
THINGS I HAVE DONE:
