Ski: 2007 GTI 130 Nothing fancy just the way it was out of the wrapper.
Problem; Intermittently does not get the 2 beeps needed to start. (Fails more times than it works)
Observations when it fails.
First made sure I was working with the correct service manual. I had the 2007 downloaded but reading the intro it clearly states that it is for a 2006. Well a 2006 has a 3-wire DRESS and an MPEM. The 2007 has a 4-wire 2 reed switch DESS post and NO MPEM. So downloaded the 2008 and it has the correct wiring diagrams. (Just a heads up.)
So this is where I am at.
So here is the question, given the sequence to complete serial number validation to get two beeps to allow the instrumentation to come on and allow the start circuit to energize to allow starting what function does the PU/BL wire serve? Also appreciate some feedback, replace DESS Post, continue to look for a bad ground or short or chase the start-stop switch circuit since it does play a roll in allowing the energizing of starting sequience.
- Depress the Start/Stop Button with no key. No instrumentation every time.
- Place key on post. No lights and no beeps. Depress the Start/Stop button, does not start and no double beeps and no lights on the instruments.
- Take the key off and on the post, give it a twist or two, maybe a cuse word or two and then out of the blue for no reason we get two beeps the ski starts and does stop till we depress the start / stop button or remove the key.
- Battery excellent
- All connections are tight.
- All fuses check good.
- Replaced 30 amp relay no change. (This was a SWAG)
- Completed all continuity checks for a 4-wire DESS post. On the last check, we are looking for 0 ohms between the BL/PU wire and the BL wire with the lanyard on the post. I never get this reading it is always open.
