caffinated
Wow.....Lots of threads to read. Haven't come across any concerning timing of six cylinder 240 EFI.
So thought I would post to pose my question.
The problem started when a tine from hydro surge lodged between stator housing and impeller.
The engine won't start when launched into water, but will when hooked up to garden hose.
I'm guessing that the stator on top of engine may have sheared a keyway, although I don't
know for sure if there is a keyway or the fit may be a tapered one. Any who, would it be possible
to check the timing or maybe to pull the flywheel to see if the flywheel continued to turn while the engine
stopped abruptly. Thus creating an advanced spark situation. The boat runs great at full throttle
but smokes quite a bit at idle and low R.P.M. Can only start in the water by jumping across the
stater leads.
Thanks in advance for any help with this dilema, Caffinated
stater leads.
