Afternoon guys. I'm not sure if you all saw my post about my XP's through-hull fitting tearing out at the lake yesterday.
I am tearing into it now and just had a few quick questions. This was a pretty easy repair last time I did it, but it seems that things tore out in a little more of a severe way this time.
The issue is that the stock plastic fitting itself tore out. So If I was to order one of the aluminum sleeve kits the sleeve would not be quite big enough diamterwise to fill the hull.
Just trying to figure out what I need to order to get this fixed.
Do I need to order a new OEM plastic hull fitting just to get the new sleeve kit in?
Do I just go ahead and slather the one I have now up in epoxy and shove it back in there?
Is there an aftermarket solution that would take the place of the original fitting?
I will include some pictures to make it easier to understand what I'm asking.
As always, I appreciate any advice or input you guys have on my situation.
