TheYeti
Well I feel like I shouldn't have touched anything until after testing my first fix. Rebuilt the carbs over winter and changed the pump oil (found what looked to be grease in there, but refilled with oil), then cleaned those rave valves. Took it out today...
Keep in mind I bought it last year at the end of the season. Took it out once and it had a carb issue so just did the rebuild and reset the screws to where they are supposed to be. Starts and idles fine first try now. When i drove it last year it would slowly build up to get to top speed but would plane high and pretty much 'catwalks' through the water. That was then after purchasing it.
Now I take it out today and it idles fine put it in reverse or forward and it will idle in either direction, but throttle up a bit and it does not want to go at all. It will rev up all the way to 7500 or so and then i put the throttle back down to idle. At one point I shut it off for awhile to let my daughter fish and it didn't want to start back up. Eventually it did after trying awhile. Not sure if maybe I shouldn't be sitting in the water not running with these things? It's my first Seadoo boat (first Seadoo anything). So before I introduce the next more obvious problem that happened. What could this be attributed too? Quick google search and the first reply is wear ring If there is a "No go issue" But I don't just want to order that take the family to the lake again and still have an issue. Any thoughts opinions?
